cbucks Posted February 17 Share Posted February 17 I have an elevation region that is -9' and an elevation region that is -11' and a driveway between the two with the one side a retaining wall and the other side a foundation wall. For some reason chief is adding a -8 region in between and a lot of little swirls. Please see attached photo. I highlighted the elevation regions in Blue and I think I snapped everything in the region against the walls Link to comment Share on other sites More sharing options...
dshall Posted February 17 Share Posted February 17 3 hours ago, cbucks said: I have an elevation region that is -9' and an elevation region that is -11' and a driveway between the two with the one side a retaining wall and the other side a foundation wall. For some reason chief is adding a -8 region in between and a lot of little swirls. Please see attached photo. I highlighted the elevation regions in Blue and I think I snapped everything in the region against the walls For the fun of it, drag your terrain break through the wall into that void space since and see what you get 1 Link to comment Share on other sites More sharing options...
