Chief42020 Posted February 9, 2024 Share Posted February 9, 2024 I have an ADA sink and toilet that needs to be 18" to center from a wall or other fixture. Usually up against a wall. This is code for commercial applications. Tired of using cad, drawing a line to measure out 18" to center for 30 toilets or sinks. How can I set the bounding box around the fixture to not allow anything within a specified distance to touch this fixture? See the attached as to what I am talking about. Comments I'm seeing don't match up with X14 Link to comment Share on other sites More sharing options...
Solution DBCooper Posted February 9, 2024 Solution Share Posted February 9, 2024 Eric's answer in the other thread only works if you are using X15. In X14, you need to use the "open symbol" and go to the "sizing" page and then type in the width you want. Link to comment Share on other sites More sharing options...
Chief42020 Posted February 10, 2024 Author Share Posted February 10, 2024 Eric, Yes, I saw your reply. Thanks Link to comment Share on other sites More sharing options...
Chief42020 Posted February 10, 2024 Author Share Posted February 10, 2024 DBCooper, Thank you for keeping it simple. Mike Link to comment Share on other sites More sharing options...
