Efflorescence Posted February 1, 2024 Share Posted February 1, 2024 Hi all - I'm drafting the as-builts for a house I'm preparing to remodel. I started by modeling the main house, which is 2 floors plus a full basement. (that's on the left-hand side of the plan below) Now I'm moving on to the garage, which is connected to the main house by what I'll call a breeze-way. The main floor plan looks like this: The problem is ... the garage also has a second floor (note the stairway) but since I had Chief generate the 2nd floor for the house PRIOR to modeling the garage, no 2nd floor was generated above the garage. I hadn't drawn it yet. Obviously, in retrospect I should've modeled the entire main floor including garage, and then generated the second floor. Since that didn't happen, does anyone know of a simple way I can now add a 2nd floor to the garage building? Thanks! Link to comment Share on other sites More sharing options...
Efflorescence Posted February 1, 2024 Author Share Posted February 1, 2024 Thanks. I was expecting that to be the case too, but when I drew in the walls to create the space on the 2nd floor (see below) none of the defined spaces become "rooms." It's all non-clickable space. (if you know what I mean) Link to comment Share on other sites More sharing options...
Efflorescence Posted February 1, 2024 Author Share Posted February 1, 2024 A section through the model shows ceiling joists but not floor joists above the garage: Link to comment Share on other sites More sharing options...
Efflorescence Posted February 1, 2024 Author Share Posted February 1, 2024 Ah, good thought to check that, but that doesn't seem to be the problem. I used my default interior wall type and "no room definition" is unchecked. *IS* there a way to build a second floor here that isn't pain-staking?!? Link to comment Share on other sites More sharing options...
Efflorescence Posted February 1, 2024 Author Share Posted February 1, 2024 Ah, there we go. Worked slick! Thanks for your help! Link to comment Share on other sites More sharing options...
DBCooper Posted February 2, 2024 Share Posted February 2, 2024 I don't know if you have ever played around with reference display (F9) but turning it on makes it very easy to draw walls on your second floor and snap to the walls on the first floor. It also makes it really easy to move a wall on one floor and then jump to the other and line them back up. Link to comment Share on other sites More sharing options...
