GrizzlyBear Posted January 27, 2024 Share Posted January 27, 2024 Can someone tell me what setting I am overlooking here? I am attempting to pull a running dimension on the posts in this plan in the "Post Layout" SPV. I can do so in other plan views but not this one. I'm sure it is something simple that alludes me.Bouknight_rev2.plan.zip Link to comment Share on other sites More sharing options...
Solution ValleyGuy Posted January 27, 2024 Solution Share Posted January 27, 2024 1 Link to comment Share on other sites More sharing options...
GrizzlyBear Posted January 27, 2024 Author Share Posted January 27, 2024 I love you ValleyGuy! The I created this SPV I copied it from one that the manual dimensioning was already set from. I guess I assumed that it would copy those defaults over. Seems like best practice is to go through and verify such things as you are essentially building your template for next time. Thanks again friend! Link to comment Share on other sites More sharing options...
ValleyGuy Posted January 28, 2024 Share Posted January 28, 2024 On 1/27/2024 at 12:55 PM, GrizzlyBear said: Seems like best practice is to go through and verify such things as you are essentially building your template for next time. Thanks again friend! You are correct, the best thing is to go through each one. Before you just copy SPV, defaults, layer set lines..., try and find out all the things that you are affecting, you will find that sometimes it is best to create from a 'New' standpoint. Layer set lines are a good example, if you happen to copy a line that has display checked for every other layer set you've created and you only want this new line to display on the current layer set, you will need to revise all the other layer sets. Keep plugging away, things get easier with each new little victory. Link to comment Share on other sites More sharing options...
