myrtsbnye Posted January 25, 2024 Share Posted January 25, 2024 Hello All, Just looking for a bit of advice. I have an existing two story house w/ two car garage that has a full basement (under the house only). The client would like to change the basement to a slab on grade with 4' frost wall (attached a section of the type of foundation they'd like). There is a porch and deck. The garage floor is 24" below the main floor (I changed this to 12" for the slab, can be changed to whatever it needs to be to work). When I try to rebuild the foundation to this type I get lots of issues. The floor is 12" below the top of the stem wall in the house as well as the garage. There are other issues with heights of the rooms. The porch and deck floors are over 18" above the main floor level. Probably should be slabs as well? Anyway, would it make sense to start from scratch? I don't want to mess up the drawing too much. Thanks in advance. Link to comment Share on other sites More sharing options...
Renerabbitt Posted January 26, 2024 Share Posted January 26, 2024 2 hours ago, myrtsbnye said: Hello All, Just looking for a bit of advice. I have an existing two story house w/ two car garage that has a full basement (under the house only). The client would like to change the basement to a slab on grade with 4' frost wall (attached a section of the type of foundation they'd like). There is a porch and deck. The garage floor is 24" below the main floor (I changed this to 12" for the slab, can be changed to whatever it needs to be to work). When I try to rebuild the foundation to this type I get lots of issues. The floor is 12" below the top of the stem wall in the house as well as the garage. There are other issues with heights of the rooms. The porch and deck floors are over 18" above the main floor level. Probably should be slabs as well? Anyway, would it make sense to start from scratch? I don't want to mess up the drawing too much. Thanks in advance. Post your .plan file Link to comment Share on other sites More sharing options...
myrtsbnye Posted February 7, 2024 Author Share Posted February 7, 2024 Thanks for your reply Renerabbitt I tried to post the plan file but it was too big. I ended up just starting from scratch. Not ideal, but it wasn't a large project. Link to comment Share on other sites More sharing options...
