FitchAndCompany Posted January 23, 2024 Share Posted January 23, 2024 When I use the material eyedropper to change a material to another one, it does not always change the texture as well. Example-- I have wood cabinets- I want to paint them white. Using the material eyedropper only changes the color, and the texture of the wood is still visible. What tool can I use that will change both in one step? Link to comment Share on other sites More sharing options...
SNestor Posted January 23, 2024 Share Posted January 23, 2024 If you attempt to paint a solid color over a material that has a texture...then, once you select the material using the "spray can"...if you look along the bottom toolbar you will see a "roller". This tool allows you to blend the solid color with the material with a the texture. Link to comment Share on other sites More sharing options...
