Framing spaceing
Thomas22
Check the main layer in the exterior wall type definition, and observe whether it is 16 or 24.  If it is 16, then reframe.  If it is 24, edit it to be what you want, then reframe.
If it is 16 and reframes at 24, save the job and close Chief, go to the file in your directory, zip it, and post the file here in your next post.  And before doing that next post, go to your profile and complete a signature so we know what version of Chief you use, and the hardware upon which you run it.
