Best way to show a channel drain both on plans and 3d?
cbucks
There are linear strip drains in the Chief core catalogs. Just place one into your model. If you don't like the 2D appearance, then modify the CAD block. If you don't like the 3D appearance, search for an alternative on the web, or create your own.
