JuneberryMarket Posted January 16, 2024 Share Posted January 16, 2024 I am working on a remodel project of an existing home. There is an exterior wall here with the large room once a garage with staircase leading into the house and a little addition to the left. I am struggling to get the paint and texture to be the same as all the other interior walls within the room and the gable to be the same exterior lap siding. I have tried the manage wall coverings in the room specifications to get this far... I have also tried the 'add break' tool. Working with premier x13 on MacBook pro Thank you! Rebecca Link to comment Share on other sites More sharing options...
rgardner Posted January 16, 2024 Share Posted January 16, 2024 Open the Wall dbx>go to roof panel and look at the bottom where it says what happens if a roof cuts the wall. Link to comment Share on other sites More sharing options...
JuneberryMarket Posted January 16, 2024 Author Share Posted January 16, 2024 It sounds like that should work @rgardner! But, I am not seeing any changes when I toggle it on. Link to comment Share on other sites More sharing options...
JuneberryMarket Posted January 16, 2024 Author Share Posted January 16, 2024 I finally found it! Wall specfications, wall types, pony wall. Thanks for your help. Link to comment Share on other sites More sharing options...
rgardner Posted January 17, 2024 Share Posted January 17, 2024 18 hours ago, JuneberryMarket said: I finally found it! Wall specfications, wall types, pony wall. Thanks for your help. That will only work to one point. This is done all the time and works. 1.) make sure the wall in the structures panel is set to default top and bottom height. Once you have manually adjusted the wall that function is turned off. 2.) under roof panel in the wall dbx set the lower wall type if cut by roof to your desired interior wall type. Link to comment Share on other sites More sharing options...
