cfichter Posted December 19, 2023 Share Posted December 19, 2023 I've investigated the training videos - lots showing wall below and open below - but I can't figure out how to set a wall above (so as you walk down stairs you are encased by walls) but below staircase is open. I've tried various pony wall configs, stumped. thx for ideas/tips I'm obviously overlooking something really simple. Link to comment Share on other sites More sharing options...
TeaTime Posted December 19, 2023 Share Posted December 19, 2023 1 hour ago, cfichter said: I can't figure out how to set a wall above...but below staircase is open...stumped I'm obviously overlooking something really simple. Not really. There's no good way to do this. The program simply doesn't have an option or setting to make this happen automatically. Quite frustratingly, the opposite is rather simple: simply draw a wall under your stairs, or set a half-wall to "Follow Stairs". Done! For this though, you'll need to manually break and re-shape the bottom of the wall. I would do this in a cross section looking at the wall from within the stairs ex: In that elevation you can break and shape the wall. It'll even snap to the underside lines of the stairs, which make it easier: What it WONT do is cover the underside of your stairs, or more importantly, the exposed underside of your wall That can be covered up with a 3D Solid, Soffit, Custom Ceiling plane... But hey, you're already in an elevation to do this, so might as well create a 3D Solid while you're there. 1 Link to comment Share on other sites More sharing options...
cfichter Posted December 20, 2023 Author Share Posted December 20, 2023 Perfect, thank you so much @TeaTime - exactly what I want to do. Link to comment Share on other sites More sharing options...
