Angled wall connection
Wynsong
I have an angled wall coming to two walls at 90 degrees. The angled wall insists on showing its end dictated by the wall connection in the 3D rendering. I've tried all combinations of through walls to no avail. How to I either control exactly where I want the wall to end or get rid of the ghost end in the rendering. See photos.
Thank you, Tea Time, Had never used that button. It mostly worked but I did not find a way to edit the layers of the brick pony wall. The solution for that I came up with was to break the wall and on the section next to the intersection to turn off the pony wall and make a polygon block of brick to replace it. Also had to change the OSB texture to the log cabin texture. Thank you so much for your reply. I appreciated it.
1 hour ago, TeaTime said:
Try the Edit Wall Layer Intersections button
it'll let you pull each Wall Layer of each wall. You might have to mix techniques, pulling layers together while pulling other wall layer back. Play with it.
