modifying molding polyline
capitaldesigns
I am working on project where we have an exterior molding polyline going around the ADU. There are two exterior doors where the molding is cut (not continuing across the doors).
We made one of the door narrower. Originally it was 36" wide now it will be 30" wide. The molding has not adjusted the the smaller door. It is stopping 2" short on either side of the door.
There must me a way to adjust the molding polyline so it is cut off at the door and not 2" short. I just know how to do it.
Thanks,
Mike
I tried what you suggested. I would not work. I tried in plan view, elevation view and perspective view. There was no handles at the break on either side of the door. There is an edit handle that move the entire molding polyline around the building. I gave up and redrew the molding polyline again. That works.
Thanks,
Mike
