Joe_cul Posted October 27, 2023 Share Posted October 27, 2023 am i doing something wrong in X15. In the library browser I could click on a folder and below i would get previews on the object in that folder. Such as Showers/Shower Pans. I would see the 7 or so small previews of them making it easier to select the one i needed. Link to comment Share on other sites More sharing options...
DrawingABlank Posted October 27, 2023 Share Posted October 27, 2023 That happened to me too. Make sure the 'filter results' is checked in the settings. Link to comment Share on other sites More sharing options...
DrawingABlank Posted October 27, 2023 Share Posted October 27, 2023 If you find yourself visually searching the library results more often here are a couple tips... 1) Use tile mode. More items fit in 'filter results' panel. 2) Remove names from the tile display. Name of items can be removed in the preference tab. Preferences / appearances / library browser / filter results section. Uncheck 'show names in tile mode'. That will get more results to see. Of course, this works well when you are able to discern the item without the name. (items that include obvious differences) May not work well for selecting a 32" shower pan instead of 36" because they will look similar. Link to comment Share on other sites More sharing options...
