LoraMck Posted October 23, 2023 Share Posted October 23, 2023 I like the board and batten material, but not the wood grain texture it comes with. is there a way to make it smooth, edit the option or find something new? What I'm looking for: Link to comment Share on other sites More sharing options...
Solution TeaTime Posted October 23, 2023 Solution Share Posted October 23, 2023 Depends on the Material. And even then the answer is likely "maybe". If you open the Board & Batten material, it'll have a Texture image, and then likely a Bump Map or Normal Map. If so, you can delete the Texture and just use the Bump/Normal map - but those also might have some texture to 'em. So just removing the Texture image may not entirely get you there but it'll get you close. 1 Link to comment Share on other sites More sharing options...
