GeneDavis Posted October 14, 2023 Share Posted October 14, 2023 I needed one so modeled it in SU and did the import/make to achieve a light fixture. So here is a plan with the one I used in a plan (for hanging from a 3:12 vaulted ceiling, and one that is level. The level one is "raw," in that it needs editing to add lights and do textures. The one with the pitched canopy/transformer housing is set up with an array of 3/8 dia. point lights inside the LED light cavity. The cavity has a 1/16 thick lens I textured as Lighting White with 100 percent transparency, which one might want to tweak a little. Wac Volo Linear LED Pendants.plan 2 Link to comment Share on other sites More sharing options...
NRST8TRKR Posted October 16, 2023 Share Posted October 16, 2023 Thank you Gene, Have a great week,Ken Link to comment Share on other sites More sharing options...
