Layout box issue
JEFFRO56
I was able to move and resize the layout box in layout using edit handles. Not changing the scale of the attached view just moving or resizing the box. All of a sudden I cannot do this. The edit handles  are like frozen. Probably a simple solution but cannot find it. Guidance definitely appreciated. Using X15. Thanks!
I don't think I have seen this before.  First, try restarting Chief and if that doesn't work I would try reboot.  If it is still a problem, then maybe you accidently locked the layout box layer or did something else unusual.  You could try posting the plan and the layout to see if someone else can figure it out.
