bedford22 Posted September 22, 2023 Share Posted September 22, 2023 We have had issues when we draw our walls up and view them in the rendering. It appears when we draw them, that they connect to the foundational walls below, however, in camera view, there is a gap between the two walls/floors. How do you bring the wall down so it touches the floor below? Link to comment Share on other sites More sharing options...
DBCooper Posted September 22, 2023 Share Posted September 22, 2023 One thing that can cause this is if you have messed around with your wall top/bottom heights. You can fix them by using the "reset to defaults" tool and selecting "wall top heights" and "wall bottom heights". You may need to do this on each floor though. Another thing that might cause problems like this is that somehow you have messed up your floor platforms. Not sure exactly what would do it though because I played around a bit to try and make it happen and couldn't. For problems like this, it is usually best to post the plan. Someone on the forum can almost always figure it out pretty quickly. If the plan is too big, try "zipping" it up first (when the plan is closed) and this can make it much smaller. If it's still too big, then make a copy and delete stuff that isn't needed to show the problem. Link to comment Share on other sites More sharing options...
