5Design Posted September 20, 2023 Share Posted September 20, 2023 Thoughts? Don't know what happened, just went away.Wright Residence.zip Link to comment Share on other sites More sharing options...
TeaTime Posted September 20, 2023 Share Posted September 20, 2023 plan file is 0mb, try reattaching it - make sure it's not open in Chief when you zip it. Link to comment Share on other sites More sharing options...
Solution TeaTime Posted September 20, 2023 Solution Share Posted September 20, 2023 Just a thought though, if it's only happening with a certain type of wall, then it's a wall type issue. Open your 6" Brick wall's definition and make sure the Brick layer doesn't have "Air Gap" checked, very bottom option. That literally makes that layer not build anything in 3D. Link to comment Share on other sites More sharing options...
5Design Posted September 20, 2023 Author Share Posted September 20, 2023 17 minutes ago, TeaTime said: Just a thought though, if it's only happening with a certain type of wall, then it's a wall type issue. Open your 6" Brick wall's definition and make sure the Brick layer doesn't have "Air Gap" checked, very bottom option. That literally makes that layer not build anything in 3D. That worked. Weird thing is I didn't change anything in the definitions, it just disappeared. Love Chief's many glitches! Thanks! Link to comment Share on other sites More sharing options...
