Material continuing through a door frame
KendallDesign
I am trying to have tile continue along a backsplash that also includes a door frame.  In the door frame area the tile pattern doesn't show up.  How do I make that tile appear. Screenshots attached showing the area that the tile should be in and the appearance of the tile.  That area is a doorway.
13 minutes ago, KendallDesign said:
How do I make that tile appear... That area is a doorway.
Pretty sure they just don't work in doorways. It'd probably work fine if the doorway and wall were removed and the header area were a soffit or something.
Otherwise, slip in a 3D Solid of the same thickness as the backsplash - those things can exist anywhere they please.
