Attic wall not completely forming above gable wall
MarcSpeer
I have a design with a three car garage.  Each bay has a separate door and each bay has a different depth from the back wall.
The leftmost and shortest bay has a hip roof, but the other two have gable walls. The middle bay is the deepest of the three.
My problem is that the attic wall on the right half of the larger gable is not being generated.  I have attached pdf's of this part of the floor plan and of an elevation showing the missing attic wall.
Gable Wall Problem Floor Plan.pdfGable Wall Problem Elevation.pdf
Does anyone have any idea why this is happening?
By the way, I used to use Home Designer Architectural to do the floor plans, but hired a CAD draftsman to do final documents.  I was able to build this same design element successfully in HDA.
I switched to Chief Architect Premiere when my draftsman retired.Gable Wall Problem Floor Plan.pdf
Thanks for your help.Gable Wall Problem Elevation.pdf
