kylejmarsh Posted September 6, 2023 Share Posted September 6, 2023 Having issues exporting a layout set where the file exports a blank looking pdf. However if you inspect the pdf a bit you'll see that the text is there, but everything is just white. Here is a pdf with the issue: Plans - Evangelista - Estimate Review - Sep 5.pdf It's a small file so I assume only the text is getting added to the pdf not the vectorwork or the live views. Also should know: - Other layout files plot just fine, it's just this one .layout - Relinking the model to a different one does not help - Sending it to printer instead of pdf creates a blank sheet - Previews in print dialog show as white - I had played around with adding a watermark to this layout, which is the only thing that is different than usual (from what I can tell) Any ideas on what could be going on? Plans - Evangelista - Estimate Review - Sep 5.pdf Link to comment Share on other sites More sharing options...
VHampton Posted September 6, 2023 Share Posted September 6, 2023 In the Manage auto-archives, is there a former layout (for this project) prior to the watermark being used? If so, how does that layout print? If it works well, that's a helpful clue. In addition... To trouble shoot, have you cleared the printer cache? What happens when the print is changed to black and white? 1 Link to comment Share on other sites More sharing options...
kylejmarsh Posted September 6, 2023 Author Share Posted September 6, 2023 - B/W didn't help it - The former layout prints no problems (but it was from a while back so could be other issues) I ended up moving it over to a new layout file and prints just fine: Now here's the test: Turn on the watermark and what happens to the print? (save it first!) Looks like it works just fine... Link to comment Share on other sites More sharing options...
VHampton Posted September 6, 2023 Share Posted September 6, 2023 If an older Layout has functionality when it comes to printing, that says something. Especially when all other projects files are printing ok - including the new layout. Rather than embarking on a journey down a rabbit hole, it sounds as if all went well. Glad that worked out. Link to comment Share on other sites More sharing options...
