DesignbyBobbi Posted August 8, 2023 Share Posted August 8, 2023 Good afternoon all. Is there currently a program that uses Lidar for room measurements that is compatible with Chief. Our Design firm specializes in renovations and additions so accuracy is a must. Thank you for any information you could offer. Link to comment Share on other sites More sharing options...
Renerabbitt Posted August 15, 2023 Share Posted August 15, 2023 On 8/8/2023 at 1:45 PM, DesignbyBobbi said: Good afternoon all. Is there currently a program that uses Lidar for room measurements that is compatible with Chief. Our Design firm specializes in renovations and additions so accuracy is a must. Thank you for any information you could offer. Matterports Lidar rig or a intel realsense will give you accuracy. Nothing will do the work for you in chief but you can use the measurement tools for any point cloud based tool or import a 3d object file and line up your chief elements with the 3d mesh. Link to comment Share on other sites More sharing options...
