Changing Multi-Level Roof Plain to Single Plane Shed Roof
Drew-PRH
Good day,
This is a work in progress....
The client would like to have the main floor roof to be one continuous shed roof single plain.
All slanting to the front of home (low side to front - high to back)
It appears as though since Chief created this as a multi-plain, it can not convert to a single roof plain (I'm guessing)
Maybe this will need to be done manually?
And then there are areas where a break will need to be done to pull back slightly.
Thanks in advance! :D
Sweeping View - Plan Only.zip
50 minutes ago, solver said:
It's helpful to have an image (screen capture) showing the issue as often it will be enough to provide a suggestion, and eliminate the need to download and review a plan.
Similar-sounding words
plain is sometimes confused with plane
Yes - Correct plane. LOL
Here is an image...
Here is an additional image to the previous...
3 hours ago, GeneDavis said:
Manually edit.  It'll take less than a minute. Edit the plane at plan left to cover everything the other floor 1 planes do, then delete those other planes
Thanks Gene,
Appreciate your time and info.
