Traced Background Layer cannot find and turn-off
Kellmoo
Go to solution Solved by Chopsaw,
This is very odd.
I have imported a PDF blueprint and successfully traced all walls doors etc.
But now I want to turn-off that background layer and it's nowhere to be found under "Layer Display Options".
I think that I'm loosing my mind LOL
The easy way to do that is to use " Active Layer Display Options " and set up the Control Options to  Not " Show all Layers ".  Then when you select an item it it will display the applicable layers.   I believe the default layer for PDF's in X15 is " Picture/PDF Boxes ".
15 minutes ago, Kellmoo said:
Thank you for your reply.
I'm not sure I follow you. I don't see how I can setup the control options to not show all layers.
This is what my menu shows:
You are almost there, just a few more clicks starting with the gear tool.
Oh I see the Gear Icon symbol now.
But the don't show all layers was already un-checked.
"Then when you select an item it it will display the applicable layers"
There are so many layers shown, so I sorted by alphabet and looked for "Picture/PDF Boxes" and can't see this option.
This is what is see:
  • Solution
Yes you can select and delete but your original question was to turn off the layer as it may be useful again later on.
If you dock the " Active Layer Display Options " it should tell you what layer the PDF is on when selected.
X14 uses the " CAD, Default "  layer for imported PDF's.
Note that Eric posted an X15 screen shot above.
Be aware that there may be plenty of other things on the CAD, Default layer so that is why they changed it for X15.
Ahh okay now i see it.
Thank you SOLVER.
So after I selected the background PDF that I imported...I then clicked again on "Active Layer Display Options" and now I see it!!!!!!
But for some strange reason its not called PDF it's called "CAD, Default".
Thank you for helping me understand what Chopsaw was trying to tell me.
