2 Different Cabinet pulls on a pantry unit
TJDDesigns
I am trying to put 2 different sizes of a cabinet pull on a Pantry/utility cabinet for a client. The top door pull is smaller in length than the bottom door pull. Since I don't see a way to do this through the Full Height Cabinet Specifications menu, I figured I would manually place the pulls as a cad item and put into the correct location as a work around. But I am finding that when I try that the individual pull attaches to the cabinet as the one to use. Which would be great in most circumstances to quickly change out the pull or knob, but for this project I need them to be different. Is my only option to create a cad item from scratch so that it doesn't recognize as a pull? I am hoping to avoid this tediousness and any suggestion would be appreciated. Thanks in advance.
In the Cabinet specification, Front/Sides/Back panel, when you select a specific panel there's an "Appliance/Door/Drawer" option that allows you to edit that specific panel, and the hardware applied to it. You'll have to specify a pull from the Library but there's an Edit option there that allows you to change the size apart from the Default size.
