Drew-PRH Posted July 23, 2023 Share Posted July 23, 2023 Good day, This covered parking was done by creating Railing and Deck/Straight Deck. We would like to add say a 24" section of exterior wall covering from the top beam down. Tried some options - however no success. I suspect there is a proper way to do this?.......... Thank you - Drew Link to comment Share on other sites More sharing options...
Solution glennw Posted July 23, 2023 Solution Share Posted July 23, 2023 You could try using a Post to Beam and then increase the size of the Beam. Link to comment Share on other sites More sharing options...
Drew-PRH Posted July 24, 2023 Author Share Posted July 24, 2023 Thanks Glen!! Of course - I knew it was too easy.... - Drew Link to comment Share on other sites More sharing options...
