LeahPugh Posted July 12, 2023 Share Posted July 12, 2023 I have attached a Sketchup file of a Brizo Facuet. Is there anyone with Sketchup who can delete the drain portion of the faucet? I only need the faucet. Thanks! 65030LF-PC.skp Link to comment Share on other sites More sharing options...
Designers_Ink Posted July 12, 2023 Share Posted July 12, 2023 12 minutes ago, LeahPugh said: I have attached a Sketchup file of a Brizo Facuet. Is there anyone with Sketchup who can delete the drain portion of the faucet? I only need the faucet. Thanks! 65030LF-PC.skp 1.77 MB · 1 download See if this works for you. Brizo Faucet.calibz Link to comment Share on other sites More sharing options...
LeahPugh Posted July 12, 2023 Author Share Posted July 12, 2023 I am using X12. Can you export as a skp file? Link to comment Share on other sites More sharing options...
Kbird1 Posted July 12, 2023 Share Posted July 12, 2023 8 minutes ago, LeahPugh said: I am using X12. Can you export as a skp file? If it's imported into Chief?, you can use the Surface delete tool in a 3D Camera to remove the Drain ( piece by piece ) and then re-save it as a new Symbol. It is the "S" Icon with the red cross through it.............. your selection color won't be pink below, most likely 1 Link to comment Share on other sites More sharing options...
Designers_Ink Posted July 12, 2023 Share Posted July 12, 2023 24 minutes ago, LeahPugh said: I am using X12. Can you export as a skp file? Give this a shot 65030LF-PC1.skp 1 1 Link to comment Share on other sites More sharing options...
LeahPugh Posted July 12, 2023 Author Share Posted July 12, 2023 Thank you so much! It Worked! Link to comment Share on other sites More sharing options...
LeahPugh Posted July 12, 2023 Author Share Posted July 12, 2023 3 hours ago, Kbird1 said: If it's imported into Chief?, you can use the Surface delete tool in a 3D Camera to remove the Drain ( piece by piece ) and then re-save it as a new Symbol. It is the "S" Icon with the red cross through it.............. your selection color won't be pink below, most likely That is very helpful! I will have to try that soon. Link to comment Share on other sites More sharing options...
