Exterior Window Trim w/t Stone Wall
BrentJohnJohn
Greetings,
I have worked on this for over 3 hours and cannot find a resolution.
My issue is the window exterior trim is covered by a Pony Wall exterior stone (36" height off floor). How do I remove the stone as to not cover the trim? Also, I did create a Sill, but as you can see, the stone is protruding through.
