Snap Dimension To Custom Counter In Elevation
MarkMc
Is this my imagination?
I can't figure out what I have different here and why this is going on.
In elevation or back clipped section--
In one plan I can snap a dimension to a custom counter, in the other I can't. both X6.
I first ran across this in X7. Was working on the latest version of the "No snap" file. I went back to X6 to see if it worked there.
When I went back to X6 the first file I checked is the one that works. (Dims work)
So then figured I ought to check an older version of the other (No snap) file and that also doesn't snap in X6.
I'm guessing it's something I have different in the defaults or somewhere but going crazy trying to find it. Would appreciate a set of fresh eyes-
I don't need this often but do for this particular project. Right now I have a work around by deleting the custom counter because it will snap to an auto generated one.
