Paulco Posted June 13, 2023 Share Posted June 13, 2023 I am trying to add a gable roof over a door on a gable wall and the gable over opening tool wont do anything. any help trying to figure this out would be greatly appreciated. Link to comment Share on other sites More sharing options...
DBCooper Posted June 13, 2023 Share Posted June 13, 2023 I don't think the "gable over door" tool will work when the wall is already a gable wall. I think all it does is build a "gable line" for you automatically and the gable line won't make a gable on a gable wall. You could create a "porch" room using invisible walls or railings and then tell the program to make a gable roof over it. This will give you a slab floor and allow you to control things more automatically through the walls/room definition. You could also just create the gable using two manual roof planes. 1 Link to comment Share on other sites More sharing options...
