Kbernard Posted June 6, 2023 Share Posted June 6, 2023 Can anyone help me figure out how to get this range to sit back in the cabinet" Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 6, 2023 Share Posted June 6, 2023 You need to adjust the y & z origin values of the 3D cooktop symbol. Link to comment Share on other sites More sharing options...
Kbernard Posted June 6, 2023 Author Share Posted June 6, 2023 I do not see anywhere that allows for that adjustment. Every other time i've placed a range it goes right into the cabinet. I shows in the cabinet in the plan view but not in the 3D view. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 6, 2023 Share Posted June 6, 2023 You have to either make that adjustment to the cooktop before inserting it into the cabinet. Alternatively you can select the symbol itself. In plan view select the cabinet then hit tab to get to the CAD Block Instance. Open it and on the 3D panel you can adjust the origin offsets. This is of course the procedure in X15. Prior versions are slightly different. Please edit your signature so we know what version you are using. Link to comment Share on other sites More sharing options...
