missing wall for swimming pooland problem in turning railing (mesh ) at corner.
ozaheman
Hi,
 I'm reaching out to discuss the challenges I'm facing while designing a sunken swimming pool over a car parking area. I have attached the file for your reference.
The main issue I'm encountering is that the wall of the swimming pool seems to disappear or become invisible in the design. I would appreciate any insights or suggestions you may have to address this problem effectively.
Additionally, I'm having difficulty in properly turning the railing at the corner of at first floor. I have attached an image highlighting this particular issue. If you could provide guidance on how to achieve the desired railing design at the corner, I would greatly appreciate it.
Thank you in advance for your assistance and expertise. I'm looking forward to your valuable input.
X-14
Alienware m15 R6
nvidia 3070
windows 11
20230525- PLOT xxxxb-X14.rar163596365_Screenshot2023-05-25213116.thumb.png.427e4f81b2ff9cc9072932c561157f6d.png727459562_Screenshot2023-05-25212925.thumb.png.e4ce5162d8bb7261a88a1721b5d0fa6f.png
try overbuilding these railings out so they find each other, then you can trim them back. The problem is you're using railings. which are walls, pushed up against exterior walls, seems its having a hard time figuring out which ones to connect to which.
First, set those walls off being Rails so they'll be normal walls. then - these walls don't behave well. As frowned upon as it is, I'd suggest in this case to just pull them down in 3D.
