GRSmsdb555 Posted February 12, 2015 Share Posted February 12, 2015 Hello all, I can't for the life of me figure out how to get Chief to show door and window centers during placement with temporary dimensions. Thanks in advance. Link to comment Share on other sites More sharing options...
BryceEngstrom Posted February 12, 2015 Share Posted February 12, 2015 Dimension defaults/ Locate Objects/Openings. Link to comment Share on other sites More sharing options...
Jay_on_Cape Posted February 13, 2015 Share Posted February 13, 2015 Bryce, He said "temporary dimensions". I haven't found a way to change it..... Link to comment Share on other sites More sharing options...
GRSmsdb555 Posted February 13, 2015 Author Share Posted February 13, 2015 Hi Jay, I swore it was part of the temporary dimension options. I'm pretty green with Chief at this point. My mistake. Thanks! Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 27, 2016 Share Posted April 27, 2016 Bryce, He said "temporary dimensions". I haven't found a way to change it..... I know this is an old topic but I just happened to stumble across it and thought it could use a little clarification... Temporary dimensions get their settings from whichever annotation set/dimension default is active when you are using them. So, Bryce is correct that those settings are located in your dimension defaults. It would need to be changed for whichever dimension default is being used in the anno set you are using though. 1 Link to comment Share on other sites More sharing options...
