5Design Posted May 18, 2023 Share Posted May 18, 2023 I just imported the pdf of the drawing and used CAD tools to draw the balcony. Thanks, Biggers Residence Rail.pdfFetching info... Oval Rail.zipFetching info... Link to comment Share on other sites More sharing options...
TeaTime Posted May 18, 2023 Share Posted May 18, 2023 Looks like you've got nested CAD Blocks with the white inside bits being a solid white filled polyline - I've seen that before with white fills, not sure what causes it exactly, but I'd use the Subtraction tool to remove that section outright. You already have a solid white filled polyline behind it all, so those white shapes are redundant anyway. Link to comment Share on other sites More sharing options...
5Design Posted May 22, 2023 Author Share Posted May 22, 2023 On 5/18/2023 at 10:05 PM, TeaTime said: Looks like you've got nested CAD Blocks with the white inside bits being a solid white filled polyline - I've seen that before with white fills, not sure what causes it exactly, but I'd use the Subtraction tool to remove that section outright. You already have a solid white filled polyline behind it all, so those white shapes are redundant anyway. Expand That mostly worked. Sill adjusted a little in Bluebeam. Thanks! Link to comment Share on other sites More sharing options...
