Drew-PRH Posted May 17, 2023 Share Posted May 17, 2023 Good day, Working on creating a Privacy Wall 5' high with post legs at the bottom essentially lifting the privacy wall up 6" off grade. Going through the "Railing Specs", I can not seem to extend the post (newel) legs below the wall. Might there be a way to do this? Or should it be created another way? Here is what was done: Railing Specs: General) Railing Wall Type) Interior Railing Wall Cap) 8-1/2 x 1-1/2 Rail Style) Specify Railing - Solid Newels/Posts - Post to Rail Newels/Balusters) Railing Height - 60" Newel/Posts Width - 5-1/2" Spacing - 60" Type - Square Thanks so much in advance! - Drew Link to comment Share on other sites More sharing options...
Solution TeaTime Posted May 17, 2023 Solution Share Posted May 17, 2023 I'd create rails on Floor 0 aligned with these privacy walls, Rail Style: open, Post to Ceiling, remove Top & Bottom rail Then on Floor 1 make sure that area is an enclosed room with a Room divider as the opening, room is Open Below, no Roof, etc. The rooms Floor can dictate how high the wall starts. Link to comment Share on other sites More sharing options...
TeaTime Posted May 17, 2023 Share Posted May 17, 2023 (Oh, the slab underneath I'd make a Terrain Feature and make sure those cans are set to an Elevation Reference From Terrain.) Link to comment Share on other sites More sharing options...
