Exterior Privacy Wall with Post Legs
Drew-PRH
Go to solution Solved by TeaTime,
Good day,
Working on creating a Privacy Wall 5' high with post legs at the bottom essentially lifting the privacy wall up 6" off grade.
Going through the "Railing Specs", I can not seem to extend the post (newel) legs below the wall.
Might there be a way to do this?  Or should it be created another way?
Here is what was done:
  Railing Specs:
     General)  Railing
     Wall Type)  Interior Railing
     Wall Cap)  8-1/2 x 1-1/2
     Rail Style)  Specify Railing - Solid
                       Newels/Posts - Post to Rail
     Newels/Balusters)  Railing Height - 60"
                                    Newel/Posts Width - 5-1/2"
                                    Spacing - 60"
                                    Type - Square
Thanks so much in advance!
 - Drew
  • Solution
I'd create rails on Floor 0 aligned with these privacy walls, Rail Style: open, Post to Ceiling, remove Top & Bottom rail
Then on Floor 1 make sure that area is an enclosed room with a Room divider as the opening, room is Open Below, no Roof, etc. The rooms Floor can dictate how high the wall starts.
image.png.60da81246985a011671be36426915de0.pngimage.png.dfbff6f37c107848a878dc9814c46f1c.png
