3d Connections Devices - Configuration File
  • 3 weeks later...
If you load my configuration file, it should load the radial menus I have created. That is assuming you have a 3DConnections device.  Once loaded, you may have to map the radial menus to the buttons on your own device.  In some instances it may override your device and it's existing settings.  That is if you have the same device as me.  Currently, I have the following...
3D Connections
+ CAD Mouse Compact (Corded)
+ 3D Space Mouse 3Compact (Corded)
+ Keyboard Pro
+ Numpad Pro (Comes with the Keyboard or Sold Separately)
Now keep in mind this was tailored to my personal work flow and is actively a work in progress.  It's also tied to Chief Architect Premier X15.  It may not work with other versions of Chief Architect.  As time goes on, I will likely be revising some of the radial menus.   I plan on adding more radial menus and macros that are tied to Chief Architect tools and functions.  If you are able to access the radial menus, feel free to change and tailor this to your own work flow and needs.
