flightcrazed Posted May 2, 2023 Share Posted May 2, 2023 Hello all, I'm designing a Barn and having trouble getting the roof to sit on top of the wall like I want on the lean-to. I'm trying to design a 9' wall, sloped ceiling with shed roof on a 2:12 slope. I've attached a few views for reference. Any ideas are much appreciated! Thank you Link to comment Share on other sites More sharing options...
TeaTime Posted May 2, 2023 Share Posted May 2, 2023 Hi @flightcrazed - it's helpful when asking questions on the forum that we know what software you're using - adding it to your Signature is super handy. Looking at those images though, it looks like the missing wall is specifically on the floor above, it's likely an Attic Wall that gets automatically generated but may have been manually pulled in a camera view. First thing I'd look at is if you can select them in 3D, or at least one of them, open it's Specification window and go to the Structure section, and make sure Default Wall Top is checked. You might attach a copy of the plan that we can look at, too. Link to comment Share on other sites More sharing options...
flightcrazed Posted May 2, 2023 Author Share Posted May 2, 2023 Thank you @TeaTimefor the quick reply! I've attached the plan that I'm working with. It's in Student edition so hopefully that's not a problem. Per your recommendation, Default Wall Top is selected and it is showing as an Attic Wall. I believe the reason it's missing in the view is because it's "invisible". Is there a good way to just remove that Attic Wall? Or lower the roof plane the 1' 8 1/4"Monitor Barn 25x60 + 4 suites.planto meet the wooden beams? Monitor Barn 25x60 + 4 suites.plan Link to comment Share on other sites More sharing options...
TeaTime Posted May 2, 2023 Share Posted May 2, 2023 3 minutes ago, flightcrazed said: I believe the reason it's missing in the view is because it's "invisible". You hit the nail on the head. Simply Unchecking "Invisible" fixes this. If I were to guess, this wall was probably deleted at some point--whether intentional or otherwise. Attic Walls pop up automatically, when you delete them the program keeps them, just marks them invisible. Delete the invisible one, it becomes visible. the program put them there for a reason and it's very adamant that they stay! Whether you SEE them or not is another story. Link to comment Share on other sites More sharing options...
flightcrazed Posted May 2, 2023 Author Share Posted May 2, 2023 @TeaTime makes sense and good to know, thank you! I actually want that section of wall removed so that the bottom slope of the roof sits on the wooden porch beams. Any suggestions there? Link to comment Share on other sites More sharing options...
Solution TeaTime Posted May 2, 2023 Solution Share Posted May 2, 2023 23 minutes ago, flightcrazed said: Is there a good way to...lower the roof plane the 1' 8 1/4" to meet the wooden beams? The issue here is that your roof is set to Trusses w/ a 30" Heel, but also a vaulted ceiling Here's what it's trying to do: To complicate matters, you seem to have accidentally create Roof Baseline Polylines -- I'm not going to get into how these things work apart from just the fact that they're going to bar the roof from building properly. Go to Edit, Deleted Objects, check "Roof Baseline Polylines" (in the top group, on the right) and press OK. Then if you go to the Build Roof dialog and set it to Rafters you'll see it drop down. 1 Link to comment Share on other sites More sharing options...
TeaTime Posted May 2, 2023 Share Posted May 2, 2023 if you need Trusses, you'll need to set up ceiling planes for them to generate correctly. See: https://www.chiefarchitect.com/support/article/KB-03165/creating-a-parallel-chord-roof-truss.html Link to comment Share on other sites More sharing options...
flightcrazed Posted May 2, 2023 Author Share Posted May 2, 2023 You're awesome @TeaTime! you saved me. Thanks so much! 1 Link to comment Share on other sites More sharing options...
