Interior Cabinet Shelve in elevation view
Pam-millstrong
You can adjust the transparency of the door materials but that will affect all views of the model. I typically draw them in with CAD. Copy / Paste    Transform / Replicate etc. makes short work of adding. I don't do this 'till construction sets where changes are minor or billable.
Quick Tip:  If you want to use information from the actual cabinet shelves in the model to create your CAD lines do the following to speed up the process...
  1. Either use the Delete Surface tool to delete the door front material OR set up a temporary camera that cuts into your cabinets.
  2. Once you have the actual shelving in view, create a CAD Detail From View.
  3. Group select all the shelf lines.
  4. Paste Hold Position back into your main elevation view.
  5. While the lines are still selected, change line style to dashed.
  • Like 2
