buddy21 Posted April 29, 2023 Share Posted April 29, 2023 I'm trying to create a covered porch using the railing tool. I'm using the Post to Beam feature, but can't seem to get the roof alignment correct. Any advice would be much appreciated! Link to comment Share on other sites More sharing options...
Solution Chopsaw Posted April 29, 2023 Solution Share Posted April 29, 2023 It looks like you may have the opposite problem as discussed here: Same solution though I think. Link to comment Share on other sites More sharing options...
buddy21 Posted April 30, 2023 Author Share Posted April 30, 2023 Hi Chopsaw, Thank you so much for the response! You're correct...both solutions worked for me. I opted for the "Gable sub fascia depth change" to preserve the height of siding above the entry door trim. I am very grateful for your help! Kind regards, Steve Link to comment Share on other sites More sharing options...
Chopsaw Posted April 30, 2023 Share Posted April 30, 2023 1 hour ago, buddy21 said: Hi Chopsaw, Thank you so much for the response! You're correct...both solutions worked for me. I opted for the "Gable sub fascia depth change" to preserve the height of siding above the entry door trim. I am very grateful for your help! Excellent. If you have a moment maybe post the finished comparison so others can see the results with your procedure. Thanks, Chopsaw Link to comment Share on other sites More sharing options...
buddy21 Posted May 2, 2023 Author Share Posted May 2, 2023 Hi Chopsaw, Here's a picture of the corrected beam after changing the "Gable sub fascia" from 5-1/2 inches to 3-1/2 inches. I've since changed the beam to white but for comparison I switched back to the wood. Thanks again for your help! You save me from wasting a bunch of time. 1 Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted January 3, 2025 Share Posted January 3, 2025 On 4/30/2023 at 12:16 PM, Chopsaw said: Excellent. If you have a moment maybe post the finished comparison so others can see the results with your procedure. Thanks, Chopsaw Please support the request below to update the porch floor... Link to comment Share on other sites More sharing options...
