CanadaChristine Posted April 28, 2023 Share Posted April 28, 2023 (edited) Hi all. I have a garage wall that has a higher footing level than the rest of the house. The bottom of footing level difference is 3'10, but I can't have such a large step according to Ontario code. I turned the affected wall into a pony wall, with brick wall above the foundation level. I used the break tool to separate the foundation wall into segments, to drag each to the proper positions. Now my wall intersections with perpendicular walls are not cooperating. The perpendicular walls have extended past the changed foundation wall for some reason. On the main floor level, things still seem to be fine. What am I doing wrong? Thanks for your help Edit to initial post: The level 1 garage wall is actually not showing correctly either. Corners are off, and windows don't display in 3 D view Edited April 28, 2023 by CanadaChristine missing info Link to comment Share on other sites More sharing options...
rgardner Posted April 28, 2023 Share Posted April 28, 2023 Not sure what your exact issue is. Looks like you moved that foundation wall and did not adjust the lengths of the perpendicular walls. It appears the walls are stepped correctly. Maybe a pic describing what you need and/or the plan file? Link to comment Share on other sites More sharing options...
rgardner Posted April 28, 2023 Share Posted April 28, 2023 As a side note you can see that your wall above is not aligned with the wall below since the match wall to wall above tool is in your edit menu. Link to comment Share on other sites More sharing options...
Solution CanadaChristine Posted April 28, 2023 Author Solution Share Posted April 28, 2023 Thanks Ryan. Your second post gave me the clue that got me started on getting this resolved. Link to comment Share on other sites More sharing options...
