Chris1956 Posted April 27, 2023 Share Posted April 27, 2023 (edited) Trying to build a shed roof over a window, seems to be the new window covering. I've tried using roof plane tool , didn't work. I tried using a soffit ,no luck either. Size of roof 3'w x 32"L at (3n12 pitch)with 2 supports on each side to hold it up. I'm using X15 software. Thanks in advance Edited April 27, 2023 by Chris1956 adding the software # Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 27, 2023 Share Posted April 27, 2023 You mean like this? DJP Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 27, 2023 Share Posted April 27, 2023 The supports can be corbels from the Library Browser and you can vary the pitch via the roof specification dialog - pitch DJP Link to comment Share on other sites More sharing options...
Chris1956 Posted May 6, 2023 Author Share Posted May 6, 2023 Thank you David for your quick response. Chris Link to comment Share on other sites More sharing options...
