mpatalsky Posted February 9, 2015 Share Posted February 9, 2015 I've looked through every dialog box & I can't find a way to disable the baseboard on the stone walls. Only way I'm thinking it's possible is to remove it from the room & then make a room molding polyline & then remove from a specific wall. Is this the only way? Thanks, Mike Link to comment Share on other sites More sharing options...
Solution Dennis_Gavin Posted February 9, 2015 Solution Share Posted February 9, 2015 Basically yes. One variation is to remove or zero out height for room and then draw one molding polyline and assign molding to that. Link to comment Share on other sites More sharing options...
mpatalsky Posted February 9, 2015 Author Share Posted February 9, 2015 Thanks Dennis, that's what I figured. It would be a nice addition to the wall specification to disable. Link to comment Share on other sites More sharing options...
ArthurDent Posted February 9, 2015 Share Posted February 9, 2015 Use the make room molding polyline tool to convert your auto room molding into a manual one. Way easier then drawing your own. Then turn off the molding for each edge that is against the stone. Link to comment Share on other sites More sharing options...
