zoome360 Posted March 24, 2023 Share Posted March 24, 2023 Having issues with a wide deck causing exterior wall issues when the interior room has a vaulted ceiling. My goal is for the plan to have a wide deck and a vaulted ceiling (interior room) - Version 2 below is what I want to do. Problem is: The combination of a wide deck and vaulted ceiling is causing some siding to disappear. Any chance someone has found this same issue? Any suggestions? FYI, I can fix it by dragging the missing siding upwards. Just wanted to see if there is a better solution. Thanks, Dan BeachHouse2.plan Link to comment Share on other sites More sharing options...
Kbird1 Posted March 24, 2023 Share Posted March 24, 2023 Did you try Ballooning the Gable Wall Up ( Wall's Structure Tab ) M. Link to comment Share on other sites More sharing options...
zoome360 Posted March 24, 2023 Author Share Posted March 24, 2023 Thanks Mick. That worked. When Ceiling Platform: Automatic, the siding is clipped. When Ceiling Platform: Balloon Through Ceiling Above, the siding is as expected. Link to comment Share on other sites More sharing options...
Kbird1 Posted March 24, 2023 Share Posted March 24, 2023 Hi, Not sure what version you are using as you haven't done your Forum Signature , but if this is in X15 ? please report the Issue with the Ceiling Level etc to Tech Support. M. for your Sig. : https://chieftalk.chiefarchitect.com/topic/18908-signature-here-at-chief-talk/?tab=comments#comment-155662 1 Link to comment Share on other sites More sharing options...
