ckirste Posted March 22, 2023 Share Posted March 22, 2023 It's been awhile since I've worked in CA, and not much in V12 since I upgraded awhile ago. I don't remember temporary dimensioning looking anything like this mess. Attached are screenshots of the dimensioning defaults I've set up (some in desperation because I can't see for all the lines and numbers). How do I get rid of this? I never had a problem in past versions and am not really sure what to do now to simplify my workspace when choosing Temp Dimensions. Thank you! Link to comment Share on other sites More sharing options...
Solution SteveNovato Posted March 23, 2023 Solution Share Posted March 23, 2023 Have you tried "Edit; Delete objects", then manual or automatic dimensions? It should give you a clean slate... 1 Link to comment Share on other sites More sharing options...
ckirste Posted March 23, 2023 Author Share Posted March 23, 2023 Underline Keyboard shortcut Ctrl+U 2 hours ago, SteveNovato said: Have you tried "Edit; Delete objects", then manual or automatic dimensions? It should give you a clean slate... Thank you! I haven't used that before and it worked like a charm! Link to comment Share on other sites More sharing options...
