CElder Posted February 28, 2023 Share Posted February 28, 2023 Is there a way to get the barn door track (rail) to show in plan view? I can't find anywhere in the settings to toggle that on/off. I don't like showing the door as 100% open but would like to show how much of a wall a door will take up. I suppose I could work around with a CAD symbol but that's just adding a step every time I insert, resize or move the barn door itself. Link to comment Share on other sites More sharing options...
Designers_Ink Posted February 28, 2023 Share Posted February 28, 2023 Instead of adding them in using the door dbx, go to the library browser and manually place the rail, handle and wheels in the plan. They will show up in plan view, and you can adjust the locations in elevation view. You can still use the hardware in the door dbx so it shows up correctly in 3D when opening and closing, and just change the layer of the manually applied hardware to a CAD layer and turn it off in 3D view so it only appears in plan view. 2 Link to comment Share on other sites More sharing options...
