JECORMIER Posted February 23, 2023 Share Posted February 23, 2023 Hello All- I've searched hi and low to find the button to push on this one and have come up short. See example pic for reference. What I want to do is set up a default 1-time for certain rooms (baths, utility, mud, etc.) that when I choose that room label designation I don't have to go back in and add a room polyline or standard area polyline, choose fill type, step step step. Trying to eliminate steps. I've looked into the material region info and other areas and I just can't figure it out. I'm sure someone will answer this in about 12 seconds with a nice eye-roll and a huge sigh. I get it, but I'm done hunting this down. Thank you in advance. FLOOR MATERIAL REGION DEFAULT.pdfFetching info... 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 23, 2023 Share Posted February 23, 2023 On 2/23/2023 at 12:42 PM, JECORMIER said: What I want to do is set up a default 1-time for certain rooms (baths, utility, mud, etc.) that when I choose that room label designation I don't have to go back in and add a room polyline or standard area polyline, choose fill type, step step step. Trying to eliminate steps. Expand You can't do this at a default level but if you want to still eliminate some of those steps, just set a Fill in the Room Specification>Fill tab. You can then toggle on and off at will using the "Rooms" layer. Link to comment Share on other sites More sharing options...
JECORMIER Posted February 23, 2023 Author Share Posted February 23, 2023 Ok, great. Thank you for your help on this! Link to comment Share on other sites More sharing options...
