Cross section and elevation lines/points
HartDeNoble
I have my house set on the site plan but setback and lot lines are not 90 and 180 degree. It is a very tricky lot that drops off very quickly so I am trying to get an accurate representation of how deep the foundation walls will have to be at certain spots. I have all of the elevation lines for the topography mapped out and created the actual terrain perimeter, but I want the cross section to be a perfect 90 degree slice through the building and lot line. Is it possible to set the degree you want the cross section set at or is there a way to make it parallel to the lot line or even a wall if it is at a very weird angle?
Determine what that weird angle is, copy its value, then open Default Settings > Plan and check Additional Angles, then paste in your angle.  Your section view camera drag can now snap to your angle, no matter how "weird."
It ain't weird, it's your lot angle.
You are exactly right. Thank you for the help.
