Sloped Hood cabinet trim/moldings
LeslieSapp
I'm trying to design a hood cabinet, and am having trouble creating trim on the sloped section. The bottom rectangular section is just a soffit with a couple of moldings on it.
I used a slab to create the upper section, on which I've left the material as concrete to make it easier to distinguish what area I'm working with.
Any ideas as to how to put trim on those sloped corners? Or, alternatively, is there a better method I may use to achieve the same end?
Test and design plan.plan
 No idea what you want trim to be but- you can get the angle by starting with a side elevation, taking a detail from view. Copy the lin, maybe change layer and color- paste back into the elevation and start making solids. Then adjust from front elevation. Repeat for side. Attached plan has some of that started.
hood.zip
12 hours ago, LeslieSapp said:
try putting one on that corner compound angle.
Draw first on face, extend past edge, in plan turn the corner, go to other elevation.
Providing some clear idea of what you want to get to makes a big difference in the future.
