Layout Title Sheet - Navigate to Plan Views
Joe_Carrick
The Project Browser provides a way to navigate to various plan views.  But it's a bit cumbersome when there are a lot of views to select from.
I've been adding some Callouts to the Title Sheet of my Layout - linked to SVPs and Camera Views in the Plan(s).  This gives me a quick way to simply dbl-click on a Callout to immediately open the desired view.
Above is an example of some linked Callouts that I use that open the corresponding SVPs.
It's really helping me get to the desired view without having to search thru the Project Browser.  I still use the Project Browser for some views - but for the main ones I need to work on this is much easier.
It would be even better if the LAYOUT PAGE TABLE worked this way.  ;):D
However, that would likely only navigate to the Layout Page rather than a Plan View.
  • Upvote 4
I don't know why I doesn't because other table-like objects in CA (schedules) allow you to find the object in plan.
I wish it was some type of open-source element so we can do pull requests to help out on the development.
